Hi,
I have a shot filmed on the EPIC at a base frame rate of 25fps with the record frame rate at 50fps, redcode 9:1, shutter set at 90 degrees.
The shot is a portrait of 4 Russian miners that slowly pans and there is a considerable amount of shuddering / ghosting going on when viewing in REDCINE x.
I am working on a PC workstation. Intel Core i7 CPU 3.20 with 64 gb internal ram - Windows 7
I previewed the file in Premiere Pro CS 6 and CC when rendered there is still this same issue.
I exported as several formats from Quicktime h264 at 10,000kbs - Mpeg H264 at 10,000kbs - Avid DNxHD, MXF OP1a etc
When i viewed these exports in VLC and quicktime they also had the stuttering however the ghosting and stuttering is inconsistent, this made me wonder if it actually the machine and the way it is playing the file back, which i do not expect because it shouldn't be the case.
I decided to upload one of the exports to vimeo, still the same issue when watching it on firefox on the PC, However, I decided to watch it on my mac powerbook...the stuttering is almost completely gone and there is no longer ghosting
Is this problem purely just my pc and the way it is playing back the file?
If someone has some input or similar experiences i would really appreciate it.
You can view the file on a private vimeo link here
How does it play back for you?
https://vimeo.com/94950940
pass: testshot
I really would appreciate any feedback
Thanks in advance.
Matt
pass: testshot
Thanks in advance.
Matt
