- Thread starter
- #21
Jannard
Red Leader
- Dec 28, 2006
The PATA flash is not fast enough...
Jim
Jim
Why so late? Isn't it possible before with the camera delivery?CF (Compact Flash). With the sppeds and capacity increasing dramatically before our eyes, we see CF as an alternative in the near future so we are providing for it now. You will HAVE to carefully select CF that meets speed specs (we'll help you out) and select a "standard" quality setting to record 4k REDCODE RAW. But it will be possible by Summer or early Fall.
The same as the RED DRIVE... at least as far as we're concerned. The camera can only compress so much REDCODE per second. Since 4K@30p is the max that the camera can compress to REDCODE RAW per second, any higher data rate possible with the RED RAM is moot.
Drives are cheaper... Flash is better.
If you ask any questions about shock ratings, weather resistance or security, skip right to Flash and do not use Drives. If you are CAREFUL and on a budget, Drives can serve you well.
CF (Compact Flash). But it will be possible by Summer or early Fall.
Express Card- same story as above, different format
SATA 1.8" drives. We had hoped that these would be ready by NAB, but they are delayed a few months.
64GB RED RAM- this is two 2.5" Flash drives housed in an off camera SATA housing, very similar to the RED DRIVE case. This is what we believe most Professionals will use because of the security and speed of the unit.
Hope this helps.
Jim
How is it comparable to the Viper flash? I've talked to some DP's about the use of them in exterior shoots with unpredictable weather, but RED flash it may be worth the extra lettuce...If you ask any questions about shock ratings, weather resistance or security, skip right to Flash and do not use Drives. If you are CAREFUL and on a budget, Drives can serve you well.
Jim
Can you guys support P2 as well? I really like buying my flash memory at 6x market price. :devil:
A year ago I was excited having my new HVX... Today I look at it and I feel as if I got taken by a used care salesman.
lol, I know the feeling, then again, it has made me quite a bit of money and it gave me a toy to fall back on at all times, I'll always be thankful for the HVX with or without its flaws.
On another note...I can't seem to get away from this forum, keyboard, and refresh button tonight! For hours now every time I hit refresh there are several new posts on multiple threads. How's a guy supposed to shut his computer down and go to bed when her's paranoid he might miss something?! I got this natural RED buzz going...and I'm liking it!
- The photo adaptors are going to be PL to EF adaptors or a whole new mount that needs to get rid of the standard PL ?.
I've had that exact same problem for the last 6 weeks or so... I'd call it an addiction, but it's probably lack of any real work to do other than babysitting a render farm all day long.
can the 320 gigabyte RED DRIVE be used with a HVX?
No. A FireStore or similar has hardware/software in it that knows how to take a DV or DVCPRO HD stream coming in over FireWire and write it to disk. The Red Drive doesn't know how to do this, and doesn't even have a FireWire port (it uses SATA, via a custom connector).
