Speed up Monkey Extract
Nikolai Pigarev
Moscow, Russia
Not sure if anyone had the same problem. But when rendering FCP XML using Monkey Extract full 4K my CPU was only 20% in use.
Making a copy of Monkey Extract and running as a second instance rendering a different portion made great progress CPU usage jumped to 40%. I assume that can be scaled endlessly :) as long as you have a fast RAID. With two instances i was already at 95MB/s
Hope it helps anyone
