Kalulu Ngilo
A nice sony recorder you can use for scratch audio. Costco has it for $59.99(rebate) in the states right now.
Noteable ports:Memory Stick : Max recording time (8 kbps MONO): 4 GB = 1,073 hrs; 8 GB= 2,147 hrs; 16 GB = 4,294 hrsHeadphone Output(s) : 1 (Minijack, Stereo)Microphone Input : 1 (Minijack, Stereo)USB Port(s) : 1 (Type-A jack), High-Speed USB Compatible
Audio Formats:Format(s) Supported : Recording - MP3 files: Bit Rate: 8 kbps - 192 kbps, VBR Sampling Frequencies: 16/22.05/24/32/44.1/48 kHz File Extension: .mp3PCM files: Bit Rate: 16 bit Sampling Frequencies: 44.1 kHz File Extension: .wavPlayback - MP3/AAC/WMA/WAVFrequency Range : LPCM 44/16: 50 - 20,000 Hz MP3 192k: 50 - 18,000 Hz MP3 128k: 50 - 16,000 Hz MP3 48k (Mono): 50 - 14,000 Hz MP3 8k (Mono): 60 - 3,400 HzMicrophone : Built-in, Stereo S-Mic MicrophoneRecording System : Digital Stereo, Monaural Recording
Check out the link below for more information:http://store.sony.com/p/Flash-Memory-Recorder,-MP3-Voice-Recorder/en/p/ICDUX533#specifications
