David Hessel
- Nov 11, 2014
Sony F35
Sony Top handle (just the handle needs to be mounted to the IF box or some custom solution to mount to camera)
Top Handle
L handle
IF Box
Assistant Panel
Riser plate
Gold mount battery plate with dtap (currently attached to the IF Box
4 pin XLR to 8 pin Lemo cable for powering the camera
Flight Case
Odyssey 7Q+
2 x 256 GB CD SSD's
Sunshade
L-battery adapter
Dtap to neutrix cable
2 x 10" coiled SDI cables
Nanuk Case
19mm and 15mm Bridge Plate (Modified to fit the F35's offset holes)
Dovetail
Dovetail shoulderkit with pad and 2 handles with rosette mounts.
Hard Case
Price: $7250 O.B.O plus shipping
I also have 3 x 95 watt batteries and 1 x 190 watt batterythat could be added as well.
Top Handle
L handle
IF Box
Assistant Panel
Riser plate
Flight Case
Odyssey 7Q+
2 x 256 GB CD SSD's
Sunshade
L-battery adapter
Nanuk Case
Dovetail
Hard Case
