SmallHD Cine7 + Start/stop signal / Extension port
Maxim Kľujev
Hello
I'm curious. Does anyone know how to use Smallhd Cine7 on V-raptor and use start stop signal from Nucleus M at the same time?
- Cine7 uses external 9pin Lemo for camera control.
- If you want to use start stop signal from Nucleus you need expander (e.g. Red expander blade or new Tilta I/O module) which use same external 9pin lemo.
It look like these two things exclude each other.
Any thoughts?
Thank you.
You would need to get the 4-pin CTRL cable for the Cine7 & then on the Expander Blade or other IO module you would plug it into the Ctrl Port & then plug your Nucleus into a 3-Pin R/S Port on that IO breakout with the 3-pin Fischer cable.
https://smallhd.com/collections/red-...-pin-usb-cable
Thank you so much for your advice. I am already thought about this solution, but there is almost no info about new accessories and whether it support full communication between Raptor and smallhd.
So If 4pin CTRL port would do everything as would with 9pin directly... it's great solution, Thank you very much!
