[FS: GEAR] Small HD C-Stand with Table Stand Kit
Jani Häkli
Active member
  • Quickly go from a C-stand to a table or cart
  • Adapts to secure mounting solutions utilizing the built-in VESA mounting holes
  • Table Stand is designed to be mounted to a C-Stand with no interference
[TD="class: specs-label, bgcolor: transparent"] Height [/TD]
[TD="class: specs-label-value, bgcolor: transparent"] 11" (27.94cm) [/TD]
[TD="class: specs-label, bgcolor: transparent"] Width [/TD]
[TD="class: specs-label-value, bgcolor: transparent"] 14" (35.56cm) [/TD]
[TD="class: specs-label, bgcolor: transparent"] Depth/Length [/TD]
[TD="class: specs-label-value, bgcolor: transparent"] 8" (20.32cm) [/TD]
[TD="class: specs-label, bgcolor: transparent"] Weight (Item Only without battery) [/TD]
[TD="class: specs-label-value, bgcolor: transparent"] 49.6oz (1406.13g) [/TD]
[TD="class: specs-label, bgcolor: transparent"] Weight (Packaged) [/TD]
[TD="class: specs-label-value, bgcolor: transparent"] 64oz (1814.37g) [/TD]
Never used, new in box.$ 200 plus postage. Located in Sydney Australia.
email jani.hakli(at)me.com
