BrandonChristensen
Any indication on when they might fill the line up out?
Bumping this back to the top.
Last I heard, the 32mm was supposed to be December, and we're right smack dab in the middle of December, so who knows.
Totally agree Paul!
I hate ring bokeh created by aspherical elements!
It's ugly!
On the K35s for example it's something that really holds them back (for me at least)...
An 18mm - T2.1, APO lens with Full Frame coverage at a similar size/weight and price point without using aspheric and floating elements? That is simply impossible.
Even Zeiss' CP.2/CP.3 line is T2.9 for the wide end (15mm, 18mm, 21mm) as opposed to a T2.1 stop for focal lengths past 25mm.
Back in 2015 when the 50mm T2.1 came out, SLR Magic ran a poll asking about what focal lengths should be next and the widest option was "21mm at T3.1"
The only way we are getting an 18mm at T2.1 is if it only covers S35 or if they use some sort of removable tele adapter (T2.1 for S35, T2.9-T3 for FF - a 1.4x tele adapter would work as it gives a 43.96mm diagonal (44mm is around what is needed for FF coverage, and I came up with the 43.96mm number by adding 31.4 (coverage needed for S35) x 1.4 (adapter magnification factor with one stop loss).
I'm quite surprised by the Sigma 24-35. Being a zoom, the Bokeh is quite nice and soft; and lack a hard ring around it. It seems a bit warmer vs. the SLRs
You are absolutely correct. All I'm saying is that it's been done and that the economies of scale play a huge part in camera lens tech- make the impossible- possible![]()
The 18mm summicron from Leica is nice and not a dissimilar size. Is that aspherical? (no idea here...)
Paul
Fair enough.
"The use of exotic aspherical elements in each Leica Summilux-C lens creates a telecentric path of light from the rear element to the sensor. Telecentricity and aspheric correction not only reduce chromatic aberrations and color fringing, but also create a more even illumination across the entire field. "
Also, they only cover a bit past S35 (36mm) so not really relevant.
Fair enough.
You know there’s two Leica lenses being discussed here ?
The summicrons are the T2 and summilux are the faster lenses (also heavier and more expensive)
JB
All single sensor, photo film lenses are single plane focusing. It's like saying "gluten free potatoes" - just a marketing phrase...So anyone knows how you go about designing an APO lens (i believe all RGB colours hit the focus plane at the same time)
cheers
Paul
- Paul, you probably meant "at the same plane", not time? As for APO design, here I have nothing to say except we all know like it needs complex design, abnormal glass and aspherics....
So anyone knows how you go about designing an APO lens (i believe all RGB colours hit the focus plane at the same time...
Generally speaking, yes they are.All single
sensor, photo film lenses are single plane focusing...
