Mestizo Devon
Is there a proper firing order to adding batteries so the camera rolls over? Redvolts first and then vmounts, antons.... or vmounts first and then revolts???
So you can pop on an Anton bauer and then a REDVOLT, then the scarlet will roll over to the side handle after the anton is dead?I believe some had issues and the solution for them was the order in which the batteries were inserted. I personally never had a problem with REDvolts and Anton combo.
My Epic has never just switched over without a specific order. That order is, install revolt, boot up on it only, then power down. Then install AB, and boot up again. After this hot swapping AB works every time.
