Shutter Angle Setting (Build 20)
Jeffrey Hamlin
Hey Ya'll....
With build 17 I was able to monitor the shutter angle in the EVF. Now that I am at build 20, I no longer see the shutter angle displayed. I know the formula (Shutter Speed x Frame Rate x 360) so we don't need to go there. I just wanted to know what happened to the shutter angle display.
Thanks all.
J
If I'm understanding correctly, you see the shutter speed and not the shutter angle displayed in the evf? If that's the case, it's a simple change in a menu:
System button > Setup > Preferences > Display > Shutter (change from "1/sec" to "degrees").
Hope this helps.
Clint
