T_Freundlich
- Nov 6, 2012
- Finland
- www.freundlich.org
Hi guys,
Today I found myself running into a weird issue I don't remember seeing before: For some reason my R1MX won't let me select a shutter angle wider than 180 degrees. I was trying to set it up for 25 fps with a 1/25 sec shutter but the shutter speed comes out red if I try to go longer than 1/50 sec, and the exposure doesn't change either. Shorter shutter speeds work normally. Previously I seem to recall that the red number was only displayed for impossible shutter speeds slower than the framerate.
Couldn't find anything in the manual except this on p. 43:
NOTE: If the operator requests a shutter speed (angle) that is outside the capability of the camera in that mode, the actual shutter speed (angle) used will be reported in red text.
Why should this be outside the camera's capability? Is this a bug (on Build 32) or am I missing/forgetting something blindingly obvious?
