- Moderator
- #61
Jeff Kilgroe
Yes, once it's up and running, keep it running in the cold. It's much better for the equipment to keep its temperatures constant.
And I don't recommend running RED Drives or any other spinning media drives in sub-freezing temperatures. It's notoriously hard on any HDDs. The times I've had to shoot to drives in the cold, I've kept the drive(s) warm with the batteries. When using a drive, I would keep it inside my coat in and internal pocket, use the 6ft cable.
I made my own warmer for the old EVF back when I still owned it. I used a heater I found online that could power from a USB port and wired it up inside the end portion of a coat sleeve I cut from an old coat. I sewed it together on the one end and left a couple holes for the EVF mount and cable.
Black balance is always recommended before starting any important shoot. Sensor temperature can have an effect on it, hot or cold. But if you black balance with the camera indoors and warm and then take it out into the cold for shooting later, it's definitely something to check.
We keep batteries in a vehicle or in an insulated bag. Throw some hot packs in the cooler or bag.
Have had troubles with RED batteries and chargers in extreme temperatures. Batteries don't like to charge properly if frozen or if they're too hot.
