Kevin Rasmussen
- Apr 13, 2009
- Age
- 41
- Toronto, Canada
- www.collectivevolution.com
I shot a feature last year that involved a number of action sequences including explosions and blank firing guns.
I had real problems with the rolling shutter when it came to the blank firing weapons, I was prepared for this and figured it might be an issue but on our budget there was little I could do about it. We tried various shutter angles, smaller loads in the blanks, and in the end, I found that if the over all brightness of the image was high enough it minimized the effect of the split screen/rolling shutter artifacts and made the footage usable. When combining a 90 degree shutter and a 1/4 load blank in the full auto weapons for day exteriors, the rolling shutter effect would only be noticeable to a cinematographers eye.
We ended up scrapping half a sequence in a dark tunnel set with a blank firing AK-47 because the drastic lighting change from the muzzle flash was wreaking havoc with the electronic shutter and the split frame effect made the footage un-usable.
I also had numerous problems with the hard drives dropping frames when the cameras where within 15 ft. of an blank firing automatic weapons. This was solved by switching to CF cards, forcing me down to RC36 but eliminating the drop frame issue.
Since we've been greenlit for a sequel to that film, and we'll be using our trusty RED M-X again, I'm wondering if anyone has had similar experiences and whether there are any clever work arounds or solutions to making blank firing guns and RED actually work together?
My first thought last year when prepping was to shoot the gun fight sequences on 2-perf 35mm and now that I've got a budget that can afford to actually go that route it's looking to me like the best option. I guess another other option would be to pump way more light in the darker sets and bring things down in post, treat it like I'm shooting really high speed or something but I still think the muzzle flash from a weapon like an AK-47 is so massive it's still going to end up splitting frames..
I'm feeling the 2-perf 35mm at the moment since I could really use the extra latitude for all our explosion/fireball SFX photography as well.
Thoughts? Suggestions?
Kevin
Kevin
