Setup guide/help for Premiere Pro CS5 Mac?
David Callahan
Oklahoma City, OK
I'm brand new to Premier and checking out Premier CS5. Is there a post or link about the setup for a Mac? I'm not on Snow Leopard but it seems like I should be (currently running OSX 10.5.8). Is this correct?
On my first attempt I got lots of stuttery and inconsistent playback of R3D's, and even some SD footage I successfully captured.
Also, any chance of editing Red footage and getting the video out of a Kona LHe card?
Current hardware:
8 core 2.26GHz
12 GB RAM
NVIDIA GeForce GT 120
4 TB RAID (apple software striped)
KONA LHe running latest drivers for Mac
Thanks!
– Get a better card, like the GTX 285
– Get a serious RAID
– 10.5.8 should be fine
– Get more RAM, at least 2 GB per core
Works very well here.
CS5 is always 64 bit, but a program can run in 64 bit under Leopard.
David,
I did a review on CS5 and discuss RED in the article as well.
http://digitalfilms.wordpress.com/2010/07/08/adobe-premiere-pro-cs5/
Part of your issue may be the sequence size. I had better performance results when I stayed in a native 4K timeline. When you work with the native RED footage and place it into a 1920x1080 timeline, the graphics card (for the computer display) goes through two scaling calculations. One for the timeline scale and a second for the screen display resolution. Staying 4K eliminates one of those. Also take a look at your playback resolutions. "Full" will really challenge your machine. Throttle it down to half or lower.
I didn't test with a hardware I/O card.
- Oliver
1. Drag one of your clips into the "new item" icon at the bottom of the project panel. It will automatically configure the sequence to match your footage, much like FCP 6&7 does with it's "match sequence settings to clip?" dialog.
2. in the source and program monitor, click on the icon on the top right, a drop down menu will appear. Set your playback and paused resolution to something low, like 1/8 or a 1/4.
