Sensor Centerpoint out of x axis
Thanks, artbeatsart. I am checking the routing of our trouble tickets to see if anything went awry between you and us.
BC
Tested three different zooms and its always exact the same also when we turn them upside down. So there is for sure not the problem on the lenses which costs nearly three times than the body of the red one.... :)
Heh Rainer:
Could it be that the mount is not in line with the sensor when you move the backfocus? Try changing the backfocus somewhat...I know the focus may not track correctly, but I am wondering if the actual mount on a thread is causing these descrepancies......shims maintain the plane of the PL mount to the sensor......a thread could cause an angle change.....
