Daniel Reed
- Nov 1, 2011
- SF Bay Area
- www.nextbooth.com
I'm looking to pick up a mic for on camera scratch audio that in a worse case scenario can be used as option B/backup audio.
In a perfect world i'll be using a Sennheiser MKH-416 as the primary audio capture mic on a boom or stand and use the on camera mic to assist with sync.
I've used the ME66 before for on camera, and found it rather effective for creating scratch audio(or even usable sound bites) for outdoor/noisy environments, but never tried it indoors. I've read that it's not so good indoors due to off angle reflections
So I was intending to pick up a K6 power cap, then I could swap between the ME64 and ME66 mics on based upon location/set/distance to subject.....
...Until i stumbled upon this video review:
To me, at least in this sample, the MKE-600 sounds a lot cleaner.
If you've used the MKE-600 before, how was it?
I've got an A-box and a fancy shock mount (forget the model atm) that can extend mic a bit forward/back and rotate the horizontal angle a bit for better mic directionality.
On a side note, I've used R0de mics before, and just not a fan.
Thank You
Thank You
