SDI monitor chain -full crew filming
JB Earl
Active member
what are good options for chaining an EVF, focus monitor, and client/director monitor with the Komodo. Worried about latency with EVF and focus monitor...
Is it possible to use a BNC Tee? I've only used Komodo once, had trouble with the wireless image.
I don't think you can use just a Tee but this DA should work
Blackmagic Design Mini Converter SDI Distribution 4K. $295
https://www.adorama.com/bmmcsdid4k.html
Theres a cheaper version if you only need 1080P for $159
Thanks Michael.
Are there any real world builds out there, or is everyone using Komodo for a run and gun?
Thanks Patrick, do you mean the tee will work with an EVF on one side, and a focus monitor on the other? I would then go out of the focus monitor to Directors monitor...
I'm using the tiny little 12g DA from Freak Show that you can velcro to a battery. Gives you two full strength 12g lines for about $300.
