S35 lenses on a FF35 camera would work fine, they just won't cover the entire sensor so you'd have to do some cropping to get rid of the vignetting.
The real issue for me is, if you decide, let's say, to use a combination of S35 cine lenses and a few still camera lenses so that when you wanted to safely expose the entire FF35 area, you could switch to the still camera lenses... is there an easy way to switch mounts or are you going to have to put PL-mounts on all your still camera lenses to match your PL-mount cine lenses?
