* Salty Surf ARRI ALEXA MINI and MINI LF water housing *
steven michelsen
CAPE TOWN SOUTH AFRICA
Hey guys selling my water housing for any ARRI Alexa Mini Mini or Mini LF camera. Im moving onto a RED V-Raptor X for an upcoming project so it will be redundant in our company. It will will come with 2x Ports listed below. There is options for a few other ports if needed. We paid over $20'000.00 for the kit as seen. It's been used on 3 jobs but absolutely mint condition. Great rental item if you interested in branching out.
*EMAIL ONLY CORRESPONDENCE * NO VAT CHARGED ON SALE *
STEVIE@HEYMANGOFILMS.COM
PRICE: $13500.00 shipping will be TBC
WITH LISTED BELOW
1X HOUSING $14'600.00
1X 18-35MM PORT SIGMA $1350
1x WOODEN CAMERA V-MOUNT POWER PLATE $350
1X 85MM PORT SIGMA $1100
1X 50M WATER PROOF NAUTICAM SDI and ARRI WCU-4 CONTROL CABLE $1090
1X SMALLHD CINE 7 WITH ARRI CONTROL LICENSE $2500
1X SMALLHD SDI BULKHEAD $200
1X VIVID LEAK SENTINEL V6 WITH PUMP AND BULKHEAD $495
1x 100mm LENS LMM *
1X 150MM LENS LMM *
1X ALEXA MINI SIDE PANEL *
1X ALEXA MINI LF SIDE PANNEL *
2X CHEESE PLATES $200
1x DUMB BACK *
2X BASE PLATES *
1X SPARES BOX *
*SALTY DISCRIPTION*
This is a new modular housing setup that allows you to configure the housing to suit different monitor setups, as well as add ‘lens motor modules’ to extent the front of the housing to accomodate lens motors.
The housing is designed to accomodate both EF lenses as well as larger PL and LPL lenses.
We have ports for various cinema lenses included Cooke Panchros and Signature Primes.
The price includes the full kit listed below.
We are unable to seperate modules, and housing is only available to purchase as the full kit.
Included
  • Housing shell
  • Monitor back for CINE 7 and other similar sized monitors
  • ‘Dumb’ Back for use without a monitor
  • Basic front module, for use with manual control ports
  • 100mm lens motor module
  • 150mm lens motor module
  • Control panel for Alexa Mini LF
  • Control panel for Alexa MINI
  • CNC machined aluminium base plate and stainless mounting hardware
  • CNC machined aluminium dual handle video grips with ODI VANS grips (various colours available)
  • ‘CINE’ port front module
  • Cheese plates
  • Camera Configuration
    Our ALEXA Mini LF Production Housing is optimised for the following camera configuration:
    • ALEXA Mini LF Camera OR ALEXA mini
    • Wooden Camera PRO Battery Plate included
    • SMALLHD CINE 7 (other similar size monitors will fit).
    • The camera battery, monitor batteries and recording storage can all be changed without removing the camera or monitor from the baseplate.
    As standard the housing is configured with our CINE Port Front Module, which allows the fitment of our CINE style ports with manual lens controls on the lens port itself.
    You can also choose to add our Lens Motor Modules (LMM), which extends the front of the housing allowing for fitment of cforce mini lens motors. A LMM and appropriate WCU-4 cabling you can have full wired lens control up to 30m away.
    There are two different lengths of LMM.
    LMM-1 is a shorter module designed for lenses with the control rings closer to the mount, such as a Cooke Anamorphic. LMM-2 is a longer module, designed for lenses with the control rings further down the lens, such as a ARRI Signature Prime.
    The LMM houses the lens motors, and then you can choose different ports depending on the total length of the lens.
