Scott Field
Active member
Lots of gear for sale! Photos here: https://drive.google.com/open?id=0B-IJwRAMcIP9LW92emE1a201ZTg
SUPPORT
(1) Sachtler Video 20S 7+7 Fluid Head + CF-100ENG HD2 Carbon Fiber Legs - $4,000 (just serviced in May)
(1) Manfrotto 529B Hi-Hat (Mounted on Filmtools Octagon Board) - $150
(1) Tilta 19mm Dovetail Shoulder Mount Handheld Rig - $300
PRODUCTION MONITOR - $1,600
(1) Panasonic BT-LH1710P 17" Production Monitor + Matthews Mount
(2) AC Power Cables
(1) PPA Int'l DVI-D > HDMI Adapter
(3) Canare 25ft SDI BNC Cables
WIRELESS VIDEO - $1,000
(1) Paralinx ACE HD-SDI Wireless Transmitter
(1) Paralinx ACE HD-SDI Wireless Receiver
(1) Paralinx ACE D-Tap Power Cable (18")
(1) Paralinx ACE AC Power Supply Cable
(1) Paralinx 18" Thin SDI BNC Cable (2 Right Angle Ends)
(1) CMR Connex D-Tap Power Cable (18")
(1) Canare 18" SDI BNC Cable
FOLLOW FOCUS - $2,900
(1) ARRI FF-5 HD base (15mm LWS)
(1) ARRI Focus Knob Standard Left
(1) ARRI Bridgeplate Adapter (19mm Studio Rod)
(1) ARRI Gear - Smaller Primes (35 tooth, 0.8 pitch)
(1) ARRI 13.5" Whip - Flexible Shaft Short + Knob
(1) ARRI Speed Crank - Focus Lever
(3) ARRI Marking Discs - Flat
TILTA SWING-AWAY MATTE BOX - $500
(1) Tilta 4 x 5.65 Swing Away Carbon Fiber Matte Box
(2) Tilta 4 x 5.65 Filter Trays (both rotate 360 degrees)
(1) Tilta Top Flag
(2) Tilta Side Flags
(1) Tilta Rubber Bellows
(3) Tilta Bellows > Lens Adapters (80/95/114mm)
(4) Tilta Hard Mattes (24-28, 35-40, 50-65, 85-180)
LENS FILTERS - All for $700
(1) Schneider Circular True-Pol Polarizer (138mm Round)
(1) Schneider UV Clear Optical Flat (4x5.65”)
(1) Formatt Hitech ProStop IRND 0.6 (4x5.65”)
(1) Formatt Hitech ProStop IRND 0.9 (4x5.65”)
(1) Formatt Hitech ProStop IRND 1.2 (4x5.65”)
CASES go with respective
(1) Pelican 1550 for Matte Box + Follow Focus etc
(1) Cases By Source ATA Spectra Case for (Monitor + AKS)
(1) Skyline Mirage Telescopic Transporter Case (Tripod)
END
SUPPORT
(2) AC Power Cables
(1) Tilta Top Flag
END
