john white
Selling this for a friend who is trying to offload the last of his gear from his families now defunct production co. This head and accompanying set of sticks is in LiKE NEW condition, and was used for personal projects only, no rentals. It comes with a hard case for the head, and a long case for the legs. Everything works perfectly. This sells NEW at B&H for over $12,000.00, and offers many benefits over an O'Connor 2575.
The Sachtler 3006 Cine 30 HD Fluid Head is a fluid head with a 150mm half ball with integrated flat base that allows you to use this head with a tripod with either a 150mm bowl base or flat base. It features a side-load sliding camera plate mechanism. Unlike traditional sliding baseplates that require you to slide the camerqa plate into the head, the side load mechanism allows you to snap the camera into the head, and still slide the plate foward and back to adjust the balance of the camera on the head. This is especially useful when the camera is weighed down with accessories. It is compatible with Arri and OConnor camera plates, and features a fine adjustment for a tight, secure fit.
With the Cine 150 (Long), you get a tripod that is rated at an astonishing 309 lb. It safely supports the payload utilizing reliable, time-proven aluminum alloy metallurgy with dual 35mm leg tubes. Oversized rotary stage clamps ensure easy height adjustments while wearing gloves, and the die-cast 150mm receiver accepts most cine/EFP fluid heads. Used in conjunction with the included 7023 Cine ground-level spreader, payload integrity is assured, and delicate floor surfaces are protected.
Asking price is $8,500.00. located in New York City.
B&H Link --- https://www.bhphotovideo.com/c/prod...I_5fzYMnd-sCSG92hjuh6awg198Rja50aAohjEALw_wcB
