Kevin D'Haeze
(SOLD!)
This is a beautiful, pristine set of Rokinon Cine DS lenses w/EF mount! It includes:
These are the next generation of cine lenses from Rokinon, with better color matching than the standard Rokinon Cine lenses. All lenses are in excellent shape and function very smoothly. Every lens (except for the 14mm, which has a fixed lens shade) has a Duclos attachment to bring all fronts to a unified 77mm filter dimension (80mm O.D.), allowing you to use common filters among the lineup. They also feature a uniform focus and iris gear position so lens swaps are faster.
This is an amazing set! If you get it from DuclosLenses.com, then add in all of the Duclos front rings and UV filters, it will cost you around $4,000. Ouch.
But you can get this set for just (SOLD!), which includes PayPal fees + shipping in the ConUS!
- Cine DS 14mm T3.1
- Cine DS 24mm T1.5 w/Duclos 77mm adaptor + UV filter
- Cine DS 35mm T1.5 w/Duclos 77mm adaptor + UV filter
- Cine DS 50mm T1.5 w/Duclos 77mm adaptor + UV filter
- Cine DS 85mm T1.5 w/Duclos 77mm adaptor + UV filter
- Cine DS 135mm T2.2 w/Duclos 77mm adaptor + UV filter
- Pelican Lens Case w/laser cutouts and room for additional lenses and accessories
