ROCKETCINE-X doesnt add correct audio tracks to ALE
Herman
Banned
When exporting Avid media (MXF's) with audio the ALE that ROCKETCINE-X creates does not include the audio track(s). Under the track column of the ALE (looking in a text editor) it only shows "V" it should be VA1(A2..etc) . The audio is there and when I modify the tracks in the Avid bin before I relink the media it will reconnect with the audio track(s).
I'm pretty sure this is just a bug & wouldn't require that much time to be fixed in the code. I am running build 1720.
Matthew Herman
Matthew Herman | Engineer | Deluxe New York | bydeluxe.com
The latest build fixed the issue.
Thank you for the quick response.
Any news when we will see FLUT work out HD-SDI YUV10 4:2:2 ?
