Rocket support for Color - please help us test
Status
Not open for further replies.
Rob Lohman
Red Team
www.red.com
Here's a REDCODE FCS update that includes Rocket acceleration for Color. We could really use your help in testing this before put things up on the support site.
PLEASE READ THE FOLLOWING CAREFULLY
In Color, increase the Playback Proxy resolution on the User Prefs tab to see the benefits of Rocket acceleration. On some system Color may not play 4K footage back at its native frame rate, but you should notice vastly improved playback speed for higher playback resolutions.
An updated version of the REDcode System Preferences pane is included which adds a tab to control Rocket acceleration in Color. There are three Rocket selection modes for Color: automatic, none (Rocket disabled), and specific-board. If the Rocket-selection mode is Auto or if the specifically requested board isn't available, the plug-in will try to find a Rocket in a full-speed slot, if that fails, it will select the first one that will open.
Logs on Rocket status are stored under ~/Library/Application Support/red/ColorPlugin/Logs
http://red.cachefly.net/apple/RED_FCS_30_2.dmg
Status
