Request to Red for ISO 100 setting in camera
Paul Leeming
Osaka, Japan
www.visceralpsyche.com
If anyone at Red is reading this, it would be great to have an ISO 100 option in camera for Komodo. Currently it has a lowest ISO of 250 but in post ISO 100 is also selectable (and I find, preferable in most instances).
Thanks in advance!
Paul :)
Set ISO to 400.
Go to: IMAGE/LUT.
Scroll down to Exposure Adjust.
Set Exposure Adjust to -2.
Hit OK.
That equals ISO 100.
Bare in mind if you are exposing for middle gray think of your Total Captured Dynamic Range and where that puts 18% Gray. You'll have plenty of latitude in the shadows and they'll be sparkly clean, but not much latitude in the highlights there.
Happy clean shooting.
I guess that's a roundabout way of achieving the same thing! :D But it would still be nicer UI wise just to add in ISO 100? that way the Exp -2 isn't a hidden setting which gets forgotten about.
This is so that I can shoot ETTR with a linear luma curve (setting None / None for Tone curve and Rolloff), as I find it most accurately replicates the way the world looks. Every ISO above that (yes, I know it's metadata) seems to add in a highlight curve.
Thanks for the tip Phil :)
Paul :)
