Render Issues
ThomtheEditor
Banned
Los Angeles, CA
Just tried rendering clips to a folder i had previously rendered to, it went frame by frame thru the output like it should when i look in the output folder nothing!
Now upon stashing the first render's QTs in a separate folder its going fine, something I'm doing wrong or just another weird anomaly of RedCine?
Also, is there any shortcut to cutting render times, like hitting caps in AE disables preview during render thus cutting render time in half, was wondering if there's anything like that in RedCine?
edit: just finished rendering and it rendered the base clips in my stack whereas i set the input to a higher level to render the clips across that stack? How do you do this, starting edit on a 3 RedCam music video tomorrow and am starting to freak out!
SOLUTION TO REDCINE CRASH DOWN:
I was working in my 4k 25 fps fotage to KONA 10 bit RGB redcine project when suddenly, crash down and there wasn´t way to continue working.
I made everything: reseet preram (alt+cmd+p+r), download previous version, trash library preferences, type manually redcine folder... and many more.
If somebody has this problem, the only thing I can do is the following:
Get a external disk (with firewire 800), make a sistem bakup (with carbon cloner for example), format MACINTOS HD, make 2 partitions, load tiger 10.4.11 in one of them, load Final Cut (to get final cut codecs as pro res for example), download the Redcine 090, and run it.
This is the only way to get out from the black, black hole..
Sorry my english.
