RELEASED: FIRMWARE - BUILD 16 (v3.2.5)
Brent Carter
REDUSER.NET
Irvine CA
The release version of Build 16 RED ONE firmware is now available on www.red.com/support .
SUMMARY:Updated .R3D file format, Digital Signal Processing optimization, Image Compression Optimization, addition of REDspace and RAW view modes, high contrast scene codec error mitigation, audio polarity and video sync correction, LCD image tearing reduction, Pre-Record Mode, Preliminary support for 16GB CF cards, support for 1080p 4:2:2 and RGB 4:4:4 playback of REDCODE RAW .R3D files, User Programmable Keys, RED-EVF menus, Time Code output on LEMO 5 pin timecode connector, Tonal Response Curve, editable LOOK files names, video visible during boot up sequence.
WARNING:
READ ALL INSTRUCTIONS CONTAINED IN THE ATTACHED INSTALLATION FILES BEFORE PROCEEDING. THIS IS A NO ROLL BACK BUILD. ONCE THE CAMERA IS UPGRADED TO BUILD 16, YOU WILL NOT BE ABLE TO DOWNGRADE TO BUILD 15 OR EARLIER BUILDS. BEFORE UPGRADING TO BUILD 16, YOU MUST FIRST UPGRADE THE CAMERA TO BUILD 15 V2.2.8, OR HAVE PREVIOUSLY UPGRADED TO AN EARLIER VERSION OF BUILD 16.
Thanks, BC
Excellent.
The RedCine and RedAlert versions are currently marked as Beta. Will those versions be changed to release versions, or should we expected upgraded versions? Thanks.
Seems like edge focus assist went from black and white to color somewhere between early 16 and later 16 too. Or am I imagining that?
Oh, release version!!! I was wondering what was new...
Do you ship the new cameras (~2400<) with Build 16 (3.2.5)? Does this mean that new REDs are incompatible with Build 15 (and lower)?
Fantastic timing - we're just about to start a feature!! Now there are no more excuses for staying Build 15 (Build 16 has recently been the most stable Red build I've ever seen). Congratulations on another milestone!
