RELEASED: Build 21 Firmware (v21.3.2) - Release Build
Bakur - it's for the Cooke S4i lenses. Camera will display lens information for the S4i Cookes - similar to the ipin data from the red zooms, etc.
But I don't think it is enabled by default. You have to go into the camera preferences to turn it on.
System > Setup > Remote -- S4i Lens
System > Setup > Preferences > Display -- Lens Data
We do own Cooke S4 lenses. And I have all the menu enabled. But no information is displayed on screen. Do I need any additional equipment for this data to be displayed? Cables maybe? Or these are several pins that are next to sensor (on the upper side of lens mount on the camera) and I do not need anything else, except proper lenses.
Was Your camera sent in for the audio-board/iPin (FREE) upgrade?
That's the only thing I can think off...
If not - contact Your bomb-squad rep...
:devil: Peter
you need to update your cooke lenses firmware. Cooke makes a USB cable that plugs into the lemo connector on each lens. If you are a legitimate owner of Cooke lenses, you will be emailed a link to the upgrade area so you can do it yourself or just send them to ZGC for upgrade.
We have purchased cameras and lenses 2 months ago maximum. Lenses are straight from Cooke. Do you think we still need any updates?
Possibly. It depends on when they were manufactured. The best way to tell is to hook them up and see. You'll need a Windows PC and the serial cable from ZGC. Les periodically emails us with updates to the firmware to keep everything current. Check with Cooke/ZGC if you're not sure. They'll be able to help.
W
Lens Data
Lens Data
You do need the specific firmware build loaded into the Cooke lenses.
Lens Data visible in Red LCD but can't find the metadata
The latest release version of RED ONE camera firmware has been posted on www.RED.com/support: Build 21 RED ONE Firmware, v21.3.2. This is a password-protected download.
SUMMARY: Addition of 4.5K WS (Widescreen) resolution; addition of REDCODE 42 for 4.5K WS, 4K 2:1, 4K ANA, 4K HD; addition of color space VIEW indicator; addition of Video Genlock for HD-SDI PVW output; support for s4/i data from Cooke Prime and Zoom Lenses; enhanced USER PROFILE function; addition of project CONFIGURATION function and camera STATUS overview; addition of REPEAT FRAME and IN-RECORD flags and CLIP NAME as HANC VITC-2 metadata in PVW HD-SDI output; changed Edge Highlight color from red to blue, variable OPACITY of LOOK AROUND area.
Read all instructions contained in the installation readme file before proceeding with download.
If you have any other questions or feedback, please contact Technical Support at www.RED.com/support.
Thanks, BC
I have upgraded the fleet of Red Ones and have my Cooke s4/i enabled, but I don't know where the lens data is stored in the metadata and whether it's available. Any ideas if the data is available and how to access it.
Richard
:devil: Peter
Peter you need a 250.00 dollar lemo to serial computer cable (PC) from ZGC. The cable will be able to update the latest firmware from Cooke. Contact Cooke for access to the latest firmware. Upgrade the lenses with newer firmware, I believe it's 0.39. The Red will see your Cookes, still trying to get information from Red about lens metadata and how to access it.
