Garrett M. Smith
What are the pixel dimensions of the anamorphic modes? i.e for 4k, is it using the full 2540 pixel height of the sensor?
Garrett
Garrett
That's what I thought. Good stuff.
Except... isn't it something like 3.56:1 unsqueezed? you have to crop again to get 2.4:1 on a 16x9 sensor...?
"Addition of root directory (.RDM) to digital media"
What does this do?
Will this allow us to record in multiple formats on the same media without formatting?
with built 14 we could use SONY 8GB CF cards,396x46MB/s, No problem with every supported frame rate. With built 15 we can not - media too slow.
we know that the speed of the card is nearly the same as the RED cf card,
it is a little faster than the RED.
Anybody with same experiences?
Maybe even better would be pushing up or down jumps up in increments of 10 or 20, and turning the knob is for fine adjustments.
Its 2304 pixels high and therefore 1.2 x that dimension wide = 2764 x 2304
Removing color on the viewfinder menu and shooting in BW seems to make it's way to RedCine?!!
We know the camera records raw so it must be getting saved as metadata. I think in RedCine you can reset/ignore all metadata from the camera somehow. Try that.
I think that choices made on the Viewfinder settings should be for the viewfinder only and not be recorded to the metadata.
...I was just trying to help you with this particular clip.
It has been like that since build 1.I don't think you need to explain it. I think everyone can see it's a bug and they'll squash that one easily.
it seems to me that viewfinder choices should not make it's way into the color workflow.
If an operator wants to shoot BW for whatever reason (maybe to make the Red highlight easier to see) then great--but it should not then require extra effort in RedCine and RedAlert.
