David Mullen ASC
Moderator
There's a difference between an underexposed image that is meant to stay underexposed-looking and one that is meant to end up looking normally exposed.
After all, you could have a shot done at 2000 ASA but have part of a room several stops underexposed, rolling into blackness -- that's not really "underexposing" the shot, i.e. rating it even faster -- it just means that parts of the frame are below key exposure.
You could even have the whole shot below key for a dim effect, but it's not necessarily going to get noisier if you never try to lift it up in post but leave it dim. So I don't really consider that sort of thing as defacto rating the camera faster because it's never going to be corrected up to normal brightness (hopefully.)
That test of Leonardo DiCaprio, for example, was done at 2000 ASA but obviously much of the frame is a number of stops below key exposure.
But if you are talking about taking a 2000 ASA shot that was two-stops underexposed and timing it to look normal in brightness, then you have defacto rated it at 8000 ASA.
