RedRushes not really using 8 cores on MacPro?
44
www.macvilleproductions.com
I just upgraded to the latest version of RR's, 3.6 and am having problems getting it to uses all 8 cores of my MacPro. When I render a clip and look at the processor usage in Terminal's TOP command, RR uses between 500% and 550%. It also says that 35% of my total processing power is being unused (about 2.8 cores as I figure.) I would love to be able to get RR's working faster as Color can currently spit files out faster. RR's does 6 minutes render per 1 hour render, Color can do 11 minutes per 1 hour render (although, I am wondering if Color debayers at half rez standard instead of high.)
Thanks,
Matthew
klick in RR on settings and set it to two clips render at the same time.... look what happens...
Give each processor 2 GB and RR will render much faster.
