[FS: GEAR] RedRock Micro Remote wireless Follow Focus w/ handwheel and wired fingerwheel
Josh Becker
Minneapolis, MN
Original kit retails for around $2800, looking to get $1500.
In summer 2016 it was sent to RedRock and they replaced a main board in the MicroRemote and updated everything to firmware 4.0. The handwheel also got a new wireless chip and they did a rebuild of the motor, so everything has been tuned up!
Includes:
Handwheel
MicroRemote BaseStation and d-tap cable
torque motor with two cables (right angle and straight)
fingerwheel w/ RedRock attachment (the universal clamp can be purchased from B&H for about $85) and fingerwheel cable
LANC trigger (used on my FS7)
IMPORTANT NOTE: Since all my other 2-pin LEMO devices use the “Arri” standard (pin 1 ground), I reversed the power LEMO on the BaseStation, the D-tap matches it. If you needed it switched back, I could do that. I also have a label on it to indicate that the LEMO was switched.
Let me know if you have any questions!
yqmNYc+
