[SOLD] RedRock Follow Focus, Chrosziel Mattebox, Alphatron EVF + Solid Camera EVF Mount
Status
Not open for further replies.
James Houk
Nashville, TN
Hello all. I've upgraded some of my gear, so the older stuff has to go. Please note this gear is all non-RED, but could be used on a RED or other camera. For me, it was used on a Sony PMW-F3. EDIT: These items located in Nashville, TN.
Red Rock microFollowFocus - v2 --$225
This follow focus is in good working order, but has a little bit of play. Includes pieces to mount on either side of camera. Setup for 15mm Lightweight rods. This follow focus is great for students or young professionals, but won't give you capabilities or responsiveness of an Arri unit. Suggested for someone who's streched their budget buying their first RED MX.
Chrosziel MB 450-01 Mattebox /w Extras -- $1,000
This kit is, for the most part, in excellent shape. It's worth noting I've lost track of the screws that tighten it to 15mm rods. Great thing about Chrosziel is there are lots of accessory bits available to customize to your rig. Best used on a 15mm LWS rig. Includes:
  • Chrosziel MB 450-01 mattebox /w 4x4" and 4x5.65" filter trays. The 4x4" filter stage rotates.
  • 15mm Lightweight rod mount. Missing screws to lock down.
  • French Flag 450-11 (Also called a top flag)
  • Side Flag set (Left & Right)
  • 450 MA Hard matte
  • 411-41-4.3 110mm-95mm pressure fit ring
  • (2) 410-39 110mm-85mm screw-in rings
  • 411-39 110mm-80mm pressure fit ring
  • 410-56 110-95mm screw-in ring
Alphatron EVF-035W-3G Viewfinder /w Solid Camera Arm -- $1,000
This viewfinder is in good working order, with the following noted defect: It has two sunspots, areas on the LCD in the lower left corner, where the pixels are burnt. This was caused by careless use that allowed bright light (the sun) to pinpoint on the screen. This defect is shown in the pictures, and I've adjusted my asking price accordingly.
Included is a D-tap power cable, and the solid camera EVF mount arm. Designed with the Berkey plate for the Sony F3 in mind, this arm allows a great deal of positioning flexibility, while maintaining rigidity during operation.
Status
