Adrien oneiga
Hi,
I've been exporting r3d Trims for a project, sofar my workflow was such.
Load Mini Mag with base station, open up Redcine (latest version)
Use in + Out points and export subclips / trimmed file back into the same folder on the minimag. Delete long master clip.
after about 3 mags worth, i start running into weird export errors on random clips.
scenario 1:
"finished with error" (and usually in the sidebar " error parsing RMD xxxx : premature end of document?"
scenario 2:
upon export , immediately jumps to 100% but still "running" in the export mode. not possible to cancel / abort clear .. redcine runs fine in the meanwhile, i can jump back into edit more, select new clips and even queue them... but it wont move past the clip, and the only thing i can do is restart the program.
with RED tech support being out another week, it really puts a damper on some projects i need to get to this week.. can anybody shed any light on this matter or suggest a possible solution??
many thanks.
scenario 1:
scenario 2:
many thanks.
