Redcine X and Audio Match
Tim Sutherland
Peyton, Colorado
I'm trying to match audio to footage in RCX. The sound department is giving me .wav files that do have timecode in them, but RCX is not syncing anything. I talked to the sound guys but they don't have any way to record them to .bwf files.
Am I missing something? Is there any way to convert the files so that RCX will use them?
Tim
What recorder are you using? Download Wave Agent from www.sounddevices.com and make sure there is timecode in the file.
Michael
I know the files have TC in them because I'm seeing it in FCP. They are using the Sound Devices 744T I think. They told me there used to be a firmware version that would let you choose BWF or WAV, but now that's gone and all WAV files have time code in them, but the extensions are .wav.
Is RCX just ignoring my .wav files?
I'm downloading Wave Agent to double check the TC in the audio files.
I thought by definition a wav file that has timecode is bwav since the additional broadcast chuck is what contained the samples from midnight to be interpreted as timecode. Perhaps as you say, RCX is only looking for a BWF extension but that should be easy enough to test - change the extension to one of your files to be bwf and see it if now starts working. If so, use a file renaming utility to batch change all of them.
Michael
I'll send the email shortly. I did get it to accept the files in Rocketcine-X but the timecode was not matched up to the right file or the right part of the correct file. Still no luck in Redcine-X.
I know the timecode matches because in FCP I can use the 'merge clips' option by timecode and all works fine, that just adds another layer of rendering time to the operation.
Tim
Tim
Try 48048 for the TC Override.
