Red Volts not charging properly
Jim Coulter
Houston, Texas USA
www.movingimageinc.com
Anyone else experiencing the issue where the Red Volt charges all the way and sometimes not at all? Even when left on the travel charger the same amount of time? It's very frustrating. I have made it a point to double check to make sure the battery is seated but it doesn't make any difference.
What does seem to help is unplugging the charger and plugging it back in before starting to charge the battery. Please chime in if you're having this issue as well and let me know what you did to fix the issue.
Thanks!
If it's flashing Red/Green I think that means that the battery is not seated properly. When it flashes orange when you put it on there you should be good to go. Ive had this issue a few times too, and it gets annoying. Usually Reseating the battery and or unplugging and plugging the charger back in works.
