Mark Madlanbayan
I have a RED Epic MX. The 5.0 touch screen is displaying fine but the touch screen functionality is not working. The side buttons are not working either. The last time I shot was maybe a month ago and everything was fine. the only thing I think i did was I tightened a screw on the SSD module. it seemed loose and i just tightened it up. and then when i powered it on the touch screen wasn't working. There is picture. you just can't use the touch functionality. I already tried doing a hard reset and took the side ssd module off and put it back on several times.
I tested a different screen on the camera and got the same issue. I took the screen and put it on my red gemini and it works fine on the gemini. So i thought it was the cable or the ssd. Then i tested with different cables on the gemini and the cables are working fine. So i think i have isolated the problem to the SSD side module. I contacted RED support and they said they no longer support the RED epic mx. Wondering if anyone has any ideas about what could be causing the problem and what solutions may get the touch functionality back. thank you
