Roberto Lequeux
Or a GA-EX58-EXTREME which is the same board but a bit ready for water cooling.
However, it seems that with the Gigabytes you can't be sure to get over 4.0Ghz. You should get into one expect something more around 3.7Ghz so you are not disappointed. Which doesn't sound like much unless you are using 8 or 16 threads at once.
I am trying to find out about compatibility with the P6T which will give you a bit more and actually costs a bit less.
