Gordon Prince
- Dec 31, 2006
PC side, affordable, 4k, online editing, color correcting, grading, real time, when?
Just get your script writing intern to ingest an EDL or XML list and force RedCine to only export...
_mike
Like Gavin, I believe it's the opposite. HD for indies.com has a small amount of info on Redcine / Red Pull List... though there isn't that much info on Redcine right now.Red has stated numerous times that REDCINE will not import EDLs.
PC Side:
4k RAW -> SD quicktimes -> Avid -> EDL -> Automatic Duck with Combustion & REDCine for 4k RGB DPXs -> Grade -> Replace footage with 4k source footage -> Change Workspace size -> Hit Render.
...2k 444...
antoine.
Just tell people that the RED camera shoots 4K RAW from which you can create 4K RGB, 2K RGB, or 1080P 4:4:4, or whatever else you want in data or video. I don't believe the term "4:4:4" applies beyond HD video anyway. Once you're talking about 2K data files, the correct term would be "RGB". But certainly, 1080P 4:4:4 is an option.
You Should be able to render to any codec install on your hardware from REDCINE, so why not Cineform 2k 444. But depending on how many hours you have shot, it might be quite a lot of HDD space.
antoine.
I don't believe that this is true. From what I have seen of REDCINE, it has a very finite (and predefined) number of output formats. I agree, it would be nice, but I don't hold much hope for this being the case.
REDCINE will output to any Quicktime codec
