Marcus Mizelle
[SOLD]
RED Pro Zoom 18-50mm f2.8 PL mount in good condition. Produces a great cinematic image.
A quality workhorse Cinema zoom lens you can stay on all day. asking $2800 obo
RED ZOOM 18-50mm Lens TECH SPECS:
Focal Length Range: 18-50mm
T Stop Range: T3 - T22
Maximum f Stop: f/2.8
Close Focus from Lens Front: 1.73 inches
Length from Front of Lens to Image Plane: 6.16 inches
Minimum Marked Object Distance: 8 inches
Maximum Format Covered: Super 35mm
Diagonal Angle of View for 30mm Image Circle: 75.72 - 31.27 degrees
Iris Scales: Two opposing scales, whole stops marked
Angular Rotation of Iris: 48 degrees
Iris Drive Gear: 116 teeth 0.8 metric module x 0.2 inches wide x 2.91 inches from image plane
Focus Scales: Two opposing scales, footage marked from infinity to MOD
Angular Rotation from Infinity to MOD End-stop: 175 degrees
Angular Rotation Between End-stops: 180 degrees
Focus Drive Gear: 128 teeth, 0.8 metric module x 0.2 inches wide x 4.37 inches from image plane
Zoom Scales: Two opposing zoom scales
Angular Rotation of Zoom Scales: 51 degrees
Zoom Drive Gear: 125 teeth, 0.8 metric module x 0.2 inches wide x 3.59 inches from image plane
Length from Front of Lens to Lens Mount: 4.12 inches
Front Diameter: 4.5 inches
Weight: 1.05 kg / 2.3 lbs.
