Red One battery/hdmi glitch??
Leo Burton
www.3barrelsmedia.com
Was on a shoot yesterday, when the battery died. When we put on a fresh battery, it wouldn't boot up when I pressed the main power button. It kept trying to boot for a few seconds, then shut down.
I figured maybe something was shorting out, so I removed the HDMI cable to my SmallHD DP4, and it powered up fine.
Is there a reason for this I should be aware of?
Not the same scenario, but yesterday I had the monitor refuse to sync with R1, despite repeated unplugging, turning off and on, etc..
It required a R1 reboot to get it to sync. Very time consuming and annoying on set.
I've had this happen with older batteries. Basically, it takes a giant amount of volts to power up a R1. Once it gets going it's less. Example: With a Red Drive plugged in one of my older batteries won't power the camera up. Unplug the Red Drive no problem. It's possible that the HDMI connection drained a small about of power or possibly you were running the DP4 from the same power supply. Just enough to drain a modicum of power.
These cameras are power whores. So my guess is your battery was not max power or not providing quite enough volts/amps. Hope this helps. j
By any chance were you using the 90 degree hdmi elbow adaptor that came with the DP4? I had some camera crashing issues with this a while back.
Chris
That sounds about right, it was an old battery! Thanks for the info, it makes sense. I think I need new ones.
