Darren O'Mahoney
New member
- Sep 7, 2014
Hello hello.
TL;DR: Red cine pro software seems to be playing back red footage recorded at 60fps, as 30fps when a monitor TV is plugged into my MacBook Pro. When the monitor is unplugged, it plays back (according to cine pro) at 60fps, and appears faster. The Avid DNxHD LB proxy files also seem to play back fast. BUT... the footage is of a helicopter pass by of some tress, and it seems too fast to the producers (it's not obvious which one is correct, people can't agree), so it might be wrong. The proxy files play in Premiere/Avid/VLC faster, but slower in Cine Pro software.
We need to make sure we are recording and playing back 60fps, and playing it back at the most accurate speed. Any help how to make sure that the proxy files aren't actually wrong/buggy, and are actually playing back too fast, and the Red Cine Pro footage is playing back at the correct slower speed? I was told that it was my MacBook, because it didn't have enough RAM, it was playing back the proxy files faster then they should (interpretation 60fps as 30fps in VLC/Prem/Avid etc). (laptop is 15inch Touchbar MacBook Pro with 16gb RAM).
We didn't notice till hours later, after trying to rule out RAM as the problem on a much much more powerful and RAM strong laptop, that the Red Cine Pro software says it's playing the 60fps back stuff as 30fps. which is why it appears slow, and the Proxy's appear correctly faster. But the producer is sure the Proxy files are too fast, much faster then she remembers flying in the helicopter. The footage says in Red cine pro 'recorded frame rate: 60fps. Also in premiere/avid/VLC, it says the proxy's are 60fps.
Is there any way to be really sure either way? It's so confusing, and took up hours of working on the RAM problem red herring, hours wasted, producers and director with the hump. Days lost to this problem, I also now look like a complete idiot. I posted a while ago about a RED/AVID workflow for a location edit.
HDRx MODE! Also if anyone also knows, if HDRx mode on RED cameras is limited to 30fps, or half of your project setting time base of 60fps? Trying to record 60fps footage in HDRx mode (not all the time, just odd occasion, but similar problem as above. The footage appears to be 30fps when in RED Cine Pro software, says 'recorded frame rate: 30fps'. But again, the proxy files play back faster then it does in the RED Cine Pro software. This could just be the A frame option of the HDRx mode, with the. X frame also being 30fps. Maybe the actual file played out/Proxy file is actually 60fps after all).
To make matters more confusing, the proxy files say they are 60fps. And play back double speed as the footage in the RED cinepro software, which plays at 30fps, and says that the project time base is 60fps, but the recording frame rate is 30fps.
Please help, its completely messing up our shoot and screwing me over!
