[SOLD] Red Gemeni 5K Camera kit, 7 inch mon, 2*480g mag, etc…
Status
Not open for further replies.
Lots of extras,
low hours (381 hours), 7 inch monitor, and 2*480 cards, I/O expander among others
I am focusing more on drone right now, and with the global situation being what it is I can't keep it all.
DSMC2 GEMINI 5K S35 BRAIN
DSMC2 RED Touch 7.0" LCD
Tilta PL Mount, and woodencamera ef mount (never used it, bought 2nd hand)
DSMC2 V-Lock I/O Expander
2 RED MINI-MAG - 480GB
DSMC AC Power Adaptor
RED MINI-MAG Reader
Top plate, and bottom plate, Rodclaw (from Duclos)
top small rig handle, small rig screen sunshade, right angle power connector
2*98W nano core v-mount batteries and x2 - core charger
For the mags, if you look at the details, you will see one is labeled as 512G and one 480, but those were just historical differences coming from Red, the size is exactly the same (as you see on the two monitor shots)
In terms of mount I always used the tilta PL mount. It works great. I did buy a used woodencamera ef mount, just in case, but never had to use it.
I put back the bottom plate on the camera (but screw it in tightly yourself) just to protect the camera. It is a good plate (don't remember the brand), the previous one had some play so I switched it.
The batteries are a bit high and their p tap port if used may block some sdi cable, but they are thin and can be taken on airline.
For Pictures please check here :
https://www.gearfocus.com/red-gemeni-5k-camera-kit-7-inch-mon-2-480g-mag-etc-.html
Status
