[FS: RED Cameras] RED Epic-X Dragon 6K Basic Kit Mag 5" Touch 18mm Lens PL Mount Baseplate Rods
Brandon W
Marketplace Vendor
Brain: RED Epic-X Dragon 6K (Hours of Operation: 2,264 (We also have brains w/ lower hours, message us if you're interested)
Price: $5,995
Monitor:
RED 5" Touch
Modules:
REDMAG Side SSD Module
15mm V Mount Battery Plate
DTAP Lemo Power Cable
Media:
64GB 1.8" MAG
1.8" Reader w/ USB cable (USB-C Cable Upon Request)
Power:
Power Adaptor
Lens & Lens Mounts:
TI PL (EF, Nikon and Leica Mounts available upon request)
RED Pro 18mm T/1.8 w/ PL Mount (Metrics)
AKS (All Kinds of Stuff):
15mm Baseplate
15mm Rods (Pair)
18" STR-STR Lemo LCD Cable
Custom Fitted Hard Case
A Whole New Beast
With the 6K RED DRAGON sensor, you can capture over 9x more pixels than HD. Unrivaled detail and impressive native exposure eclipse 35mm film in both latitude and image density. Industry leading specs distinguish the EPIC DRAGON as a model for image innovation, helming the evolution of digital cinema technology.
Bigger is Better
Resolution is more than just attention to detail. From large objects to granule textures, 6K images cultivate the nuance of every image, leaving nothing behind. Improvements to micro-contrast and MTF produce a cleaner image, drastically reducing moire and aliasing artifacts. When outputting 6K files to 4K or HD, your image will appear more refined and detailed compared to those captured at lower resolutions. The choice is simple; Bigger is better.
Still Camera? Motion Camera? Both
6K resolution translates to over 19 MP, packing the same detail you expect from your DSLR into a cinema camera. When you can capture motion and stills in 6K 2.4:1 at up to 100 frames per second (fps), or 6K Full Format at 75 fps, you get up to 100 chances per second to capture the perfect picture. Every still is raw and Adobe Photoshop compatible, which means your workflow doesn't need to change-even if technology does. The RED DRAGON sensor blurs the line between motion and still cameras, giving you the best of both worlds.
New Sensor, Same Gear
Just because your specs changed, doesn't mean your gear has to. All existing accessories, rail components, and modules designed for EPIC-X or M are compatible regardless of what sensor is installed. Instead of making your accessories obsolete, RED proudly takes great care in making sure your equipment lasts as long as possible. Change has never been so easy.
A New Look
A new sensor means a new look, and REDCINE-X PRO gives you all tools you need to dial in your image the way you want it. With its latitude at 6K resolution, you can play with color, curves, and composition with less limitations than ever before. Now with the introduction of the RED ROCKET-X card, your RED workflow just got 5x faster than ever before.
EPIC Features
New Color Science
Your image is only as good as the color science behind it. The new RED DRAGON sensor features our most advanced color science yet, taking advantage of vastly improved dynamic range and low-light capabilities. Skin tones are softer, primary colors are more vibrant, and subtle color variations are discernibly remarkable. EPIC DRAGON cameras capture images that are true to life, with colors that can only be described as "brilliant".
Same Mounts More Lenses
Leica-M, Canon, Nikon, and PL lenses are all compatible with EPIC DRAGON cameras. All mounts are easy to swap out and are engineered to fit precisely, without ever having to adjust back focus. A redesigned sensor window allows for the use of wider Leica-M and Angenieux lenses, while also providing a larger field of view when shooting. Every lens is a new perspective and the EPIC DRAGON lets you pick the one that works for you.
Higher Dynamic Range
The RED DRAGON offers dynamic range that was once thought impossible for a digital sensor. Such wide latitude provides cinematographers and photographers alike with the ability to take on challenging lighting conditions, without the need for excessive filtration. Improved low-light capabilities let you shoot at ISO 2000 and still produce a clean image fit for theatres or publication. Dilated exposure and improved sensitivity makes it easier to take on the unpredictable and capture the unbelievable.
Bigger, Better 3D
Compact form factor, 6K resolution, and wide dynamic range makes the EPIC DRAGON a perfect solution for 3D capture. Ample resolution provides VFX artists with a more malleable image that is easier to manipulate and compose for 3D work. As with the EPIC MYSTERIUM-X, the EPIC DRAGON is widely compatible with 3ality Digital 3D rigs, including the EPIC-inspired ATOM 3D rig. When you're done shooting, you can bring your stereo 3D footage into REDCINE-X PRO for viewing, color correcting, HIT/VIT adjustments, and exporting. When it comes to 3D blockbusters, there's only one choice if you're thinking big picture.
Blazing Fast
The EPIC DRAGON clocks up to 100 fps at full 6K resolution, merging the worlds of hi-speed with hi-resolution. For even faster speeds, simply drop your resolution and take advantage of maximum speeds of up to 150 fps. With blazing fast hi-speed capabilities, there's nothing that gets past your EPIC DRAGON.
We can customize the perfect camera package for you. Please message us if you wish to change anything in this kit. We are happy to add, remove, or sell items individually. We have almost every RED camera accessory and can tailor the perfect kit for your needs.
FREE SHIPPING via UPS Ground included for all 48 contiguous states. Insurance not included unless specifically requested by buyer.
We have lots of other gear available such as:
ARRI Alexa Mini
ARRI Amira
ARRI Alexa Classic
RED Monstro 8K VV
RED Ranger Gemini 5k
RED Gemini 5K
RED Carbon Fiber Weapon 8K
RED Epic-W Helium 8K
RED Weapon Dragon 6K
RED Scarlet W
RED Raven
RED Scarlet-X Mysterium-X
Cooke S4/I Lens Set
Cooke Anamorphic/I lens set
Arri/Zeiss Ultra Primes
Zeiss Standard Speeds
Zeiss Super Speeds
Arri/Fujinon Alura Zooms
Leica R's
RED Pro Primes/Zooms
We BUY, SELL, TRADE or CONSIGN professional grade cinema cameras, lenses and accessories. The equipment we are interested in includes ARRI, RED, Sony, Canon, Zeiss, Cooke, Angenieux, Fujinon, Atlas, Kowa, Hawk, Todd AO, Elite, Lomo, vintage/anamorphic lenses, Oconnor, Sachtler, Teradek, SmallHD and other pro level brands. Please message if you or your company are looking to liquidate equipment in access of $10,000.
  • CinemaCameras.com - 7.14.22 - Photo - Selects (203.1 of 284) - RED DSMC1 Epic-X Dragon 6K.jpg
  • CinemaCameras.com - 7.14.22 - Photo - Selects (203.2 of 284) - RED DSMC1 Epic-X Dragon 6K.jpg
  • CinemaCameras.com - 7.14.22 - Photo - Selects (201 of 284) - RED Epic-X Dragon 6K Basic Kit.jpg
  • CinemaCameras.com - 7.14.22 - Photo - Selects (202 of 284) - RED Epic-X Dragon 6K Basic Kit.jpg
  • CinemaCameras.com - 7.14.22 - Photo - Selects (203 of 284) - RED Epic-X Dragon 6K Basic Kit.jpg
