Jess Matney
LA Local selling a ton of gear and all in solid shape. I'm really looking to sell total packages as depicted below and will also consider a complete buy out for a cheaper rate.
I have all of the invoices and what not. Everything's priced fairly and I have plenty of pictures:
http://photobucket.com/gallery/user/...DYuanBn/?ref=1
RED Epic Dragon-M 2173hrs
RED SSD
RED PL MOUNT
RED CANON EF MOUNT
RED DSMC SIDE HANDLE
SKIN TONE OLPF
128GB REDMAG
128GB REDMAG
128GB REDMAG
64GB REDMAG
1.8 REDMAG READER
1.8 REDMAG READER
1.8 REDMAG READER POWER CABLE
5.5” RED TOUCH MONITOR
WORKHORSE LCD CABLE
5.5” HOODMAN
12” KITDIVE MOUNTING ARM
RED BRICK BATTERY
RED BRICK BATTERY
RED BRICK BATTERY CHARGER
POWER U 220 BATTERY W DTAP
REDVOLT BATTERY
REDVOLT BATTERY
REDVOLT BATTERY
REDVOLT CHARGER
RED STATION POWER ADAPTER
WOODEN CAMERA TOP HANDLE
WOODEN CAMERA TOP CHEESE PLATE
WOODEN CAMERA SIDE PLATE (LEFT)
WOODEN CAMERA SIDE PLATE (RIGHT)
WOODEN CAMERA BOTTOM EASY RISER
WOODEN CAMERA BRIDGE PLATE(19mm)
ELEMENT TECHNICA DOVETAIL
IDX V-MOUNT BATTERY PLATE
TOTAL: RED CAM+MONITOR+POWER+CAGE=$20,000 non neg or $19,000 without Wooden Camera Cage
OR
TOTAL PACKAGE:
CAM
MEMORY
POWER
WOODEN CAMERA CAGE
VINTEN150MM FLUID HEAD
RONFORD-BAKER TRIPOD
4X4 DP500 MATTEBOX
4X4 CAVISION FILTERS
SONY PL LENSE KIT 35,50,85 T2
MOVCAM 15/19MM FOLLOW FOCUS
15/19 ROSSETT HANDLE BARS
ROSSETT 15/19MM ADAPTER
TOTAL=$22,768
LENSES
ZEISS
15MM ZEISS ZE DUCLOS FULL CINE MOD F2.8 NEW FROM DUCLOS $3454 ($3140+10% CAL TAX)
28MM ZEISS ZE DUCLOS FULL CINE MOD F2 NEW FROM DUCLOS $1620 ($1473+10% CAL TAX)
35MM ZEISS ZE DUCLOS FULL CINE MOD F1.4 NEW FROM DUCLOS $2236 ($2033+10% CAL TAX)
50MM ZEISS ZE DUCLOS FULL CINE MOD F1.4 NEW FROM DUCLOS $1006 ($915+10% CAL TAX)
85MM ZEISS ZE DUCLOS FULL CINE MOD F1.4 NEW FROM DUCLOS $1620 ($1473+10% CAL TAX)
100MM ZEISS ZE DUCLOS FULL CINE MOD F2 NEW FROM DUCLOS $2236 ($2033+10% CAL TAX)
6 HOLE LENS CASE
TOTAL PRICED WHEN NEW w TAX @ $12,172
DISCOUNTED USED PRICE (15%OFF) @$10,347
SONY
35MM SONY PL CINE T2.0
50MM SONY PL CINE T2.0
85MM SONY PL CINE T2.0
LENS CASE
TOTAL PRICED AS A SET WHEN NEW w TAX @ $4017
DISCOUNTED PRICE (25% OFF) @$3,013
STUDIO FOLLOW FOCUS
MOVCAM MF1 FOLLOW FOCUS
*15/19 ADAPTER*
FOCUS RING
FOLLOW FOCUS CASE
TOTAL $650
MATTEBOX
DP500 CARBON FIBER 2 STAGE 4X4 MATTEBOX
TOP FLAG
2X SIDE FLAGS
2X 4X4 FILTER TRAYS MATTEBOX CASE *EXCHANGED FILTERS TRAYS FOR THICKER ONES*
TOTAL $200
FILTER
CAVISION 4X4 ND.3 GLASS FILTER
CAVISION 4X4 ND.6 GLASS FILTER
CAVISION 4X4 ND.9 GLASS FILTER
CAVISION 4X4 ND 1.2 GLASS FILTER
TOTAL:$200
TOTAL: $150
LIGHTING
Litegear Litemat 1 (Hybrid)
Mounting plate (baby receiver)
Hybrid Litedimmer pro (8amp)
Power Supply (8amp)
12' Hybrid feeder cable
Litemat 1 Poly Skirt
Full Grid Cloth
1/2 Grid Cloth
1/4 Grid Cloth
Litemat 1 Travel Bag
TOTAL: $800
OR $1,000 W/ Kupo Universal Light Stand
Litegear Litemat 2L (Hybrid)
Power Supply (8amp)
12' Hybrid feeder cable Litemat 2L
Poly Skirt Full Grid Cloth
1/2 Grid Cloth
1/4 Grid Cloth Litemat 2L Travel Bag
Total $1200
OR
$1500 W/ Kupo Master Double Riser Light Stand
Litegear Litemat 4 (Hybrid)
Hybrid Litedimmer pro (16amp)
Power Supply (16amp)
Litemat 4 Poly
1/2 Grid Cloth
1/4 Grid Cloth
Litemat 4 Travel Bag
Total $1500
OR
$1800 W/ Kupo Master Double Riser Light Stand
SUPPORT
VINTEN VISION 22 SD 150MM BOWL FLUID HEAD
VINTEN VISION 22 SD PAN BAR
VINTEN VISION 22 SD TIE DOWN FLUID HEAD CASE
$1500
RONFORD BAKER 150 MM BOWL TRIPOD
RONFORD BAKER 150 MM BOWL TRIPOD SPREADERS
RONFORD BAKER 150 MM BOWL TRIPOD CASE
$1200
MOVCAM ROSETTE HAND GRIPS W 15/19mm Adapter Kit $400
EASYRIG 2.5 SERIES CAMERA SUPPORT SYSTEM (5" Arm, 26 to 35 lb)
EASYRIG 2.5 SERIES CASE
$2,500
DANA DOLLY (MINT) used 4 times
*SELLING AS A WHOLE DANA PACKAGE*
Dana Dolly Portable Dolly System
2X Track Ends
2X Center Supports
100mm Bowl Adapter
150mm Bowl Adapter
3" Washer
T-Tool
16X Soft Polyurethane Wheels w/ Bearings
2 x Anti-Tip Brackets
TOTAL $600
DANA DOLLY PORTABLE RAIL SYSTEM (MINT)
6X 39” Dana Dolly Portable Aluminum Threaded Rail
(COMES IN CARRYING CASE TO EASILY THROW OVER SHOULDER)
TOTAL $400
2X Matthews Low Boy Combo Stands (MINT)
TOTAL $400
DANA+SPEED RAIL SYSTEM+STANDS= $1400
WIRELESS FOLLOW FOCUS
VARIZOOM VZ-TOC-F1 WIRELESS FOLLOW FOCUS SYSTEM (HIGH TORQUE +1000 FT RANGE+ AUTO CALIBRATE+ CAN ADD MORE MOTORS)
VZTOC-F1 High-Torque Hand Unit Hand Unit Marking Disk
Hand Unit Battery
Hand Unit Battery
Hand Unit Battery
Hand Unit Battery Charger
Hand Unit Battery Charger AC Power Cable
1 Channel Receiver
2pin To Dtap
Channel Receiver Power Cable
Receiver Antenna
VZTOC-F1 High-Torque Motor
2pin TO 2Pin High-Torque Motor Power Cable
0.5M Lens Gear
0.6M Lens Gear
2X 0.8M Lens Gear
2X Motor Antenna
Pelican Case
NEW FROM VARIZOOM $4495 (W/O TAX)
USED TOTAL $3200 INCL TAX
WIRELESS VIDEO (MINT) used 4 times
Transmitter:
Teradek Bolt 500 Transmitter (SDI)
2 pin- Ptap Power Cable
2 pin-2 pin Power Cable
BNC Cable
Receivers:
2x Teradek Bolt 500 Receivers (SDI)
DC Power Supply Cable BNCCable
2 pin to AC Power
Teradek Bolt 500 Receiver (SDI)
2 pin Power Cable
BNC Cable
2 pin to AC Power
2x 3' USB 3.0 Cable A to Micro B
Lightstand Adapter
2x Thumb Screws
NEW FROM TERADEK $4719 (INCL TAX)
RED SSD
RED PL MOUNT
RED CANON EF MOUNT
SKIN TONE OLPF
128GB REDMAG
128GB REDMAG
128GB REDMAG
64GB REDMAG
1.8 REDMAG READER
1.8 REDMAG READER
WORKHORSE LCD CABLE
5.5” HOODMAN
RED BRICK BATTERY
RED BRICK BATTERY
REDVOLT BATTERY
REDVOLT BATTERY
REDVOLT BATTERY
REDVOLT CHARGER
OR
TOTAL PACKAGE:
CAM
MEMORY
POWER
WOODEN CAMERA CAGE
4X4 DP500 MATTEBOX
TOTAL=$22,768
LENSES
ZEISS
6 HOLE LENS CASE
SONY
LENS CASE
STUDIO FOLLOW FOCUS
*15/19 ADAPTER*
FOCUS RING
FOLLOW FOCUS CASE
TOTAL $650
MATTEBOX
TOP FLAG
2X SIDE FLAGS
TOTAL $200
FILTER
TOTAL:$200
TOTAL: $150
LIGHTING
Power Supply (8amp)
Full Grid Cloth
1/2 Grid Cloth
1/4 Grid Cloth
TOTAL: $800
Power Supply (8amp)
1/2 Grid Cloth
Total $1200
OR
Litemat 4 Poly
1/2 Grid Cloth
1/4 Grid Cloth
Total $1500
OR
SUPPORT
$1500
$1200
$2,500
2X Track Ends
2X Center Supports
100mm Bowl Adapter
150mm Bowl Adapter
3" Washer
T-Tool
TOTAL $600
TOTAL $400
TOTAL $400
Hand Unit Battery
Hand Unit Battery
Hand Unit Battery
1 Channel Receiver
2pin To Dtap
Receiver Antenna
0.5M Lens Gear
0.6M Lens Gear
2X 0.8M Lens Gear
2X Motor Antenna
Pelican Case
Transmitter:
BNC Cable
Receivers:
2 pin to AC Power
2 pin Power Cable
BNC Cable
2 pin to AC Power
Lightstand Adapter
2x Thumb Screws
