frazer
- Sep 8, 2007
- Oakland, CA
- www.frazerbradshaw.com
Mostly, my camera and Red-Drive play well together, but occasionally, the formatting fails, mid stream, and the progress bars stops moving. After that, the camera won't recognize the drive, and if I try to format, it reports that it can't because the drive is too slow.
Currently running build 18, but it happened with 17, once, as well.
I've had luck, in the past, erasing it in Disk Utility and then reformatting on camera, but that's not working so well tonight, for some reason.
Anyone else have this problem and can offer advice?
BTW, I tried to search the archive, but couldn't find anything specific to this problem, so I apologize if this has been covered, already.
Thanks,
Frazer Bradshaw
DP, Oakland CA
Thanks,
Frazer Bradshaw
DP, Oakland CA
