RED Battery Problems
Paul Wildman
Toronto / Canada
www.builtbywildman.com
Im having an issue with my camera cutting out, if i bump the battery, not sure if its a battery issue or the V-Lock Mount, I don't have access to other batteries so i can't test to see which is the problem. Ive check the terminals they seem to be in order.
If you look closely at the pins on the V-Lock Mount, if there is a springy section, make sure it's sticking out enough to make good contact with the corresponding contacts on the batteries. You can use a fine instrument screwdriver, scalpel or toothpick to prise it outwards again - be gentle as prying it out too much could break it off.
On some of the old Red V-Lock plates, the springy sections would be compressed into the pins to the point where they no longer pressed against the sides of the battery contacts.
