Mark Gearhart
- May 19, 2016
The case included with the Raven is very nice, but the layout takes up a lot of space for the components so I had new foam designed for it. In this configuration, you can fit three Red Bricks, outrigger handle, 4.7-inch LCD, top handle. Camera with card installed, charger, two additional mini mags, sidewinder, 4AA batteries/charger, and mag reader. A piece of foam separates the two bricks while the rear brick appears to be mounted behind the camera, though it isn't. This is for FAA carry on flight restriction purposes. The outrigger goes in upside down and the LCD display perfectly slides into the recess on the bottom of the handle and holds firmly in place. The whole right side is available for cabling.
