Mike Hechanova
Can anyone tell me why my RCX file doesn't retain some of the recent grades that are done? If I save and close the project, then open the project, many of the recently adjusted clips on the timeline will not load with the look applied. Since I've set my preferences to save an RMD to the source folder, I can reimport the XML and then it loads the RMDs for all clips that have been graded. However, I think this creates another problem as a shot used on the timeline in multiple instances that had different grades applied can only load the most recent RMD saved and that look will be applied to all clips, so I'd have to go back and adjust creating double work.
Has anyone had this problem when loading rcx files? I'm on RCX-Pro 13. I didnt wanna upgrade to 14 mid project but maybe ill give it a shot and see if it helps. Any help is appreciated. Thanks all.
EDIT* I should have posted this in the REDCINE X section. Mods please feel free to move this or delete
