RAW Toggle bug not fixed in Build 20
RAW view
RAW view
At least, not for us... Still get the VIEW RAW user key occasionally stopping and leaving the camera stuck on RAW mode.
Which version of Build 20 are you using Cail?
when you shut down the camera , with raw-view mode toggled on,
then it will in raw-view setting after restart, not the redspace or rec709 you were using before, and the raw-view mode toggle will switch between raw-view and raw-view ... you will have to reset manually you view mode back to redspace or rec709... still the case with build 20.1.3
I can confirm that as well. If you're toggled to RedSpace (or Rec709) when you power down then the toggle remains after you've booted up again. But if you're toggled to RAW then you have to manually reset to RedSpace (or Rec709) when you power up again.
I second that. I'm tired of fixing this and explaining it.
